home Forums Parts Photos search menu
ask Ai at KQS
Kids Quad Stop
The Youth ATV App
The Quad's Axle
Let's face it, you'll go nowhere without a rear axle on your ATV... Read More ↓
Universal ATV Axles
universal ATV axlesThis is a great source for universal ATV axles in aftermarket brands like "Durable" as well as OEM factory axles. They are well known for years among dirt bike fans and now they are seen as an emerging supplier in the world of quads and ATV's.
The emergence of aftermarket axles using various raw materials has changed the way we think of axles. Durability is enhanced with some of these aftermarket brand quad axles.
Although initially known as a dirt bike catalog, Motosport has grown to include an expansive selection of ATV products.
There are numerous choices of universal aftermarket axles available since quite a few manufacturers have gotten into the axle game.
Inventory at Msport →
Universal Quad Parts
Search the universal parts listed on eBay by brand or model:
$$Paid Link
OEM Quad Axles
mojo quad axle OEM Quad axles are available for the Japanese, American, and Canadian ATV manufacturers.
Although they do stock various aftermarket ATV axles, they are a prime source for genuine OEM quad axles (or quad axels if you prefer) selected using their online fiche for all Arctic Cat, Bombardier / Can AM, Honda, Kawasaki, Polaris, Suzuki, and Yamaha quads.
The axle can be a sturdy, yet delicate part of any ATV. Many ATV enthusiasts insist on OEM replacement axles, but there are some aftermarket options for those who choose to go that route.
Mojo is set up so you can easily view and select individual parts, this makes life easy for anyone who insists on an OEM axle.
Check MojoMoto →
About Axles
The quad axle is a very important part of your machine. Simply put, it is nothing more than a rod passing through the swingarm of the ATV to the center of the rear wheels.
The rear axle is a common component on two wheel drive ATV's. Unfortunately, it is also subject to bending if it is treated to brutal riding conditions. A bent axle must be replaced in most cases, however, there are instances where they can be straightened using tools found in any machine shop.
Runout is the term used to describe the overall distance an axle is bent. A bent quad axles can be pressed back into its original condition using a hydraulic press or an arbor press and two V-blocks. Alxes are composed of hardened steel.
This makes them "springy" and a bit tricky to straighten. Typically, experimentation and experience are the magical combination for straightening a quad's axle.
Elsewhere in the ATV World
